egarant
Oct 23, 2015Nomad
Actually the skylight supplier Icon Direct directs the use of a butyl calk like Surebond SB-140 NOT a butyl tape. A generous bead goes between the vent and roof then around the edges and the screw tops.
The use of any other sealants is not recommended.
When I removed my OEM skylight, the manufacturer installed it with butyl tape and lap sealant over the top. The skylight integrity failed one one entire side where the screws were probably tightened too much.
My theory is such that being that skylight cover flanges are much thinner than a vent cover flange, the torque on the screws with the butyl tape under it caused an uneven spread of force on the skylight flange, eventually causing failure in such perfect symmetry round each screw.
Using a liquid butyl tape, provides the same seal, but would allow the torque from each screw to more easily spread throughout the skylight flange.
44,071 PostsLatest Activity: Sep 17, 2026
