theoldwizard1
Sep 15, 2020Explorer II
A small amount of butyl tape is wrapped around the screw. If you are using sheet metal screws, the tape is applied UNDER the foot of the item being fastened. If the item is through bolted (i.e. nut on the opposite side) AND the screw head is counter sunk into the foot of the item the tape is place between the screw head and the foot.
Most sailors prefer butyl tape over ANY type of caulk, because they know that they will all fail because EVERYTHING flexes ! With butyl, you simply undo the fastener, remove the butyl, clean, re-apply the butyl and reinsert the fastener.
Butyl tape or even excess butyl last FOREVER if kept tightly sealed.
44,068 PostsLatest Activity: Jun 21, 2026
