HMS Beagle wrote:
...................There are a number of people on the Ford sites that have moved the Sirius/GPS antenna just as you describe, I'm preparing to do the same thing myself. Shop manual shows the same connector near the brake pedal.
Thanks, I appreciate the info. I just located the April 2013 revision of the SVE Bulletin that covers 2011 and later F-Super Duty 6.7L Engine Stationary Elevated Idle Control (SEIC) for PTO and Battery Charge Protect modes. Looks like the wires should be in the same locations as my 2010. The newer PCM is going to require a resistor across two of the PTO inputs even if you aren't using PTO. The 2010 wasn't like that.
