bandtroberts's avatar
bandtroberts
Buying camper, need help
Hey all. I'm new to campers and need some help. I'm purchasing a Keystone Laredo bumper pull, my truck is a 2006 2500 Duramax.
1. Do I need sway bars?
2. The campground I will be at mostly only has 30 amp service and the camper is 50. Will 30 amp do any damage by not sending enough juice to a/c, fridge etc.?
3. Do I need a surge protector or some type of voltage monitor?
All I can think of for now. Like I said, brand new to campers so any tips appreciated...Thanks
  • Tvov's avatar
    Tvov
    Explorer II
    I don't think you need sway bars for a Travel Trailer (or Bumper Pull). Sway bars are usually considered needed for Truck Campers, or Slide-in Campers. Plus, are you sure your 2500 doesn't already have sway bars? In the rear, at least?
    You are going to want to plug into 50amp service when camping if your camper is setup for that. If you try to "get by" with a 30amp service, almost inevitably you'll end up trying to use too much, tripping breakers, and possibly damaging something electrical.
    NEED a surge protector? No, you don't need one. We've camped for 11 years without one, with no problems. BUT... if I was regularly using sensitive electronics (computers, etc) I would want a surge protector / voltage monitor.
  • The only question I can answer is plugging your 50 amp service into a 30 amp outlet will not hurt anything. You just may not be able to run two air conditioners and the microwave at the same time.
