BoilerEE
Mar 26, 2014Explorer
Sheriffdoug wrote:
BoilerEE,
You,ll be amazed with the Super Springs 5000+ Commercial from Michigan Truck Spring. Do not raise camper too high, but sit firm.
I also have front Timbrins & Helliwig Big Wig Sway Bar.
Good Luck, Doug.
Yep, I decided to give them a go based largely on your rec. I think my front end is good to go since the GC on mine is actually a bit aft of the axle, which I don't particularly like, but it does keep weight off the front end, which is a weak spot of my year GMC - FGAWR is only 4800# and I'm nearly there unloaded.
44,071 PostsLatest Activity: Aug 30, 2026
