lenr
Feb 16, 2020Explorer III
Changing the position of the ball mount on the shank is the only way to level the trailer even if you have to buy a longer shank to drop more (which is what I had to do). Then after you change the mount height you almost always have to readjust the WD. With systems that use chains one must be sure to have enough length for turns (Reese recommends at least 5 links under tension).
44,066 PostsLatest Activity: Apr 16, 2026
