Grit_dog
Feb 17, 2020Trailblazer
lenr wrote:
Another opinion--others will vary
With an F350, the back end will not drop much, but you will get the same leverage effect reducing the weight on the front end. Similar wheel base of an F350 or F150 will have a similar leverage effect. For best possible steering, set WD to return weight to the front end similar to what it is when the truck is unloaded regardless of if it is a 150 or 350. I set up WD on any trailer over 3,000 lb. on my F-350. Ever see a small car or small SUV pulling an over-loaded U-Haul trailer with the back end way down and the front end up in the air. Bet they were weaving all over the place for lack of steering weight.
And good luck with traction in soft, loose, wet or otherwise slippery conditions once you hook an anchor to the back of the truck and don't put enough lead in the truck's arse to increase the traction proportionally to the resistance.
Also, small car overloaded with Uhaul trailer scenario is about as far away from an accurate comparison to prove your point as it could be. At least in the context of the original question.
44,066 PostsLatest Activity: Apr 16, 2026
