Mark_Kovalsky
Jul 03, 2017Explorer
Turtle n Peeps wrote:
I didn't disagree with Mark at all. I didn't know where his temps were taken and still don't for that matter.
When I was doing cooling tests at Ford I had anywhere from 50-200 thermocouples throughout the powertrain. I had thermocouples in the ATF line into the radiator cooler, out of the radiator cooler, and out of the aux cooler. I also had thermocouples inside the radiator reading engine coolant around the transmission cooler. I had about 20 throughout the trans so that I could map the temperature gradiant inside the trans. I had them in the radiator's upper and lower coolant hoses. I had a series of them mapping the air temp into and out of the radiator. I had them outside the trans to get an idea of the air temperature around the transmission.
Let me say it one more time. "If" ATF temps are higher than the ECT's "at all times" we are all in agreement.
I can't say that.
What I can say is that after extensive testing in ambients from -40°F up to +115°F I never found a condition where the temperature inside the radiator around the transmission cooler where the coolant was warmer than the ATF. ECT often was, but that's irrelelvant. What matters is the temperature near the cooler, and I maintain that it is ALWAYS colder than the ATF.
