Reddog1
Jul 22, 2013Explorer II
Is your reference to the "top slot" mean the breaker?
Typically, is residential wiring (120-volt) uses the black as the hot wire, and the white as the neutral. If I understand correctly, in the photo the black wires go to the breakers and the white wires go to the metal block.
Simple answer to your question, if the white wire is in the breaker, and the black touches the metal block, it is probably your problem. Just reverse the wires.
44,056 PostsLatest Activity: Jan 13, 2026
