Reddog1 wrote:
Be interesting to know what kind of charging system that could charge the two batteries in thirty minutes. My charging system cannot do that. I'm guessing the two CPAPS are using a minimum of 5 amps, and the two fans another 5 amps. Collectively that would be 10 amps times 8 hours, or 80 AH.
the type of charging system that you get when you're working, on the phone, and get what you were typing for one report in the posting you were doing as a brain break.  It should have read three hours.  No, that wouldn't completely re-charge the batteries, but being new at the time they would sufficiently charge for another nights use. For the two months that we full timed across the country we had no problems with the CPAPs when we boondocked for days at a time with a mix of long and short drives between stops.  My point was that using CPAP while on the road is a rather simple and reliable process.
