jmckelvy wrote:
This is a very timely thread. My wife will be getting a CPAP machine soon. I have been researching the available machines with an eye on power requirements as we mostly camp off the grid. I do have 200 AH of AGM batteries and a built in generator.
I would appreciate it if some of you with 12 volt compatible models would list the manufacturer and model #.
There are 15-20 manufacturers of CPAP machines. I'm not familiar with all of them, but Phillips Respironics & ResMed are the two most common. The 12 volt adapters for these two machines are proprietary, the adapter for one will fry the other.
I've also used both above models plus DeVilbiss and Fisher & Paykel. Your medical provider will walk you through the various models. Most today are 12 volt compatible. One particular note, there is no need to purchase the "12 volt power pack" available for these machines, it's typically expensive & not necessary, just get the right 12 volt adapter.
On a side note: I have three machines, one in the RV, one in home & a back-up. If you need or want a second machine, Craig's List is a good source. I purchased the one for my RV with 47 hours on it for $115 & set the pressure myself. The back-up has 117 hours on it. My original machine was used nightly for 12 years straight, roughly 35,000 hours.
