Lovedays's avatar
Lovedays
Cable TV Connection
The little rubber covers for these disappeared since the last time I used my camper.
Without having to replace the entire piece that is screwed into the side of the trailer, does anyone have a suggestion for covering/protecting these?
Thanks for any idea's!
  • Get a couple of these and just cap the ends. Coax end caps
    Screw on and screw off. You won't loose these and they won't split and fall off.
  • Home depot, in the hardware Section. I have seen rubber boots inside the drawers.
    push on and pull off.
  • You need to replace the whole thing. It's really easy to do.
    Bruce
  • Radio Shack used to have metal caps that would work for you. If not there then you might try Direct of Dish TV installers. They still use them.
