kgie1217
Nov 06, 2016Explorer
punomatic wrote:kgie1217 wrote:
Biggest question is...where can I get one of these? My local dealer is backed up until December on service work. Since I'm camping in two weeks and the week of Thanksgiving I'd like to get this resolved before the 18th. Any ideas or suggestions would be highly recommended.
Here's one like yours in white. I don't know if they have black. If you are handy enough to have done all this troubleshooting, you should be able to install a replacement amplifier. If you have Amazon Prime, you should be able to get one in a couple of days...way before the 18th. First, however, check to make sure the amplifier on your current unit is switched OFF when using cable. FWIW, I had a similar problem in my coach and it turned out to be just a standard splitter; they do go bad.
I saw that one earlier today but it's for a non-amplified antenna unfortunately.
