westend
Nov 07, 2016Explorer
If it has a switch and has been operating with cable signal acceptable in the past, I'd guess that the switch is failing. Still, having a signal path through the amplifier board can't be the optimum connection. You may be losing signal strength because of the path through the board. The health of the amplifier board could be assessed by using the antenna for local stations and having the switch "on". If local stations are picked up, the amplifier may be OK.
