Travel_Junky's avatar
Travel_Junky
Cable TV issues - are we doing something wrong?
First off, we've only had our TT for 4 weeks and were out for 2 weeks on our first trip. At most of the places we stayed cable TV was offered. However, we never got it to work successfully. We changed the TV setting to "cable" and did a channel scan. All but 1 or 2 channels were full of static or wavy lines or tiling. I would suspect the coax, but there was always a channel or 2 that were crystal clear. We found that in every case we did much better with the antennae.
Are we missing something?
  • Yes, the booster button must be off for cable, and on for antenna reception.
    But, if that is not your issue, and I say this because I had other issues too... get a good piece of TV cable, test it at home so you know it works, and run it through the window at the RV Park directly to your TV.
    If it works, then screw the connection onto the unit and connect inside with the booster off. If it doesn't work, you know it's somewhere in the wiring.
    What I found, after going through this exercise was: I went into the false panel to the connection that comes from the cable outside and is the cable to my wall connection inside the camper. When I unscrewed the cable, I noticed that the center pin in the connection was shorter than usual... about 1/8th of an inch shorter... so when I screwed the cable onto the connection, the center pin was not actually connecting to the terminal.
    I put my needle nose pliers onto the center wire and pulled it out that little extra bit. After I screwed it back together, it has been long enough now for several years.
    mike
  • Possibly you have the antenna amp turned on. It's the little button on the wall plate where you connect the TV cable. It should be off for cable, on for over the air antenna.
