AnEv942
Jul 28, 2014Nomad
bikepsych wrote:
The camp site we were at last night offered 74 different cable channels. Sadly we couldn't get any of them as we couldn't find the cable connection. Had a brand new coaxial cable ready too.:-/
2013 Adventurer 89RB.
BG
Um you could have, or next time, simply run the coax thru a window-connect direct to your tv.
If your antenna connection is as pictured like Hedges, even IF you had an external connection plate, unless its connected to the inside plate you wouldn't receive any signal. Might be worthwhile to get access to the backside of inside antenna connection - if there is no wire connected to the cable-in connection, finding the external connection (if you had one) mute until you run some coax.
44,056 PostsLatest Activity: May 04, 2014
