Heavy Metal Doctor wrote:
Here's my 2 cents.....for free.....
I work on equipment that sometimes involves cables for mechanical operation of functions of the equipment. There's nothing wrong with cable systems as long as all the pieces involved are sized / engineered / assembled correctly.
When I saw the cable slide setup on the TT we bought, I was less concerned about the actual cable than about the attaching parts. The brackets where cables terminate at the wall of the slide room, specifically. I know the 3/16 or so sized cable has more than 2000lbs of pull, so I'd expect the system to rip a mounting bracket or even one of the guide pulleys loose before it simply breaks cable. Of course, there is the issue of something wearing / fraying the cable, but again, if all the pieces are aligned and operating correctly that should not be an issue.
Only about 9 or 10 months into the use of our TT, I have been inspecting the cables fairly often. So far, so good. But that's only operating them maybe 30 times in / out to date.
Spot on. I inspect my cables and mounts every trip. Also the tension screws to make sure they are not loosening like one did. I also check the cable alignment inside and out to make sure it's not cutting into anything. all that checking only takes a minute or two.
