joe123 wrote:
I had the same truck when I weighed the truck I found that if I put more than 1500pounds in the box I was overloaded, if you plan on pulling that weight and having a camper in the back you should upgrade to a I ton dully in order to haul and tow that load safely no matter what you do to the suspension you will still be on the road overloaded..
This. My '05 Ram 3500 weighs 7300 lbs with a full tank of fuel and nothing in it. Your GVWR is 8800 pounds. You definitely do not have the capacity to even carry a camper without the tongue weight of a trailer. You need a dually!
