Flyliner's avatar
Flyliner
Cabover and Towing questions
Howdy, i'm in the market for a cabover camper but before I get in over my head or too excited, I wanted to post my concerns.
I've got a '05 Dodge 2500 Longbed with a cummins diesel and automatic trans.
I've also got a 25' Parker fishing boat that weighs between 7000-9000k depending on what I put on it. That's including the trailer weight.
I'm in the process of changing from hydraulic drums to Electric over hydraulic disc brakes. Meaning, I plan on removing the hydraulic actuator/coupler and putting a fixed coupler on the trailer. This would allow me to use the proper weight distributing hitch on it if I chose to use one.
(The brakes would be actuated by a standard electric brake controller using the 7 pin wiring adapter connected to a electric brake actuator on the trailer that would actuate a hydraulic master cylinder and stop the brakes. Pretty nifty and i'm actually pretty excited about setting that up.)
Anyway, with that being said, a lot of the nicer cab-overs that i'm looking at all seem to hang over the truck bed and somewhat block the hitch.
-What type of cabover should I be looking for and can I get away without using an extension?
-If not, what sort of extension should I get?
-Is the standard hitch on the Dodge strong enough for use with an extension?
-Do I also need a WD hitch?
I want to have this kind of setup but I want it completely safe and I don't want to compromise anything especially with my family in the truck with me. Thanks all.
