ab257 wrote:
My cabover bounces quite a bit when looking at it from the drivers seat going down the road (23' long bed crew cab). But my impression is that it is the truck frame that is flexing rather than the cabover of the camper. Ford had a video a while back showing their truck and a competitors going down a railroad track, with the camera looking back at the bed. It was amazing how much the beds were flexing (of course Ford was flexing less, hence their video).
It seems to me that a cabover strut takes the forces flexing the bed and transfers them to the camper structure, reducing truck flex but increasing internal flexing of the camper. With a wood frame this might not be too bad, but would lead to stress cracking of an aluminum frame. The steel of the frame handles flexing better than aluminum.
This is different from porpoising, in which the whole truck is bouncing as a unit - air bags, upgraded shocks and Torqlifts have helped reduce that.
Also bump stops (the last resort to keep the wheel from hitting the wheel well) are different from the helper springs engager stops which are what is replaced with a Torqlift or DIY.
Hello ab257,
I’m having the same problem that you do with my cabover bouncing. I have a Chalet TS-116 camper that weighs in at 4325 LBS, when I first got it I was driving down the road and opened up my Sun Roof. Looking up at the camper through the Sun Roof made me a nervous wreck from looking at all the bouncing going on. I had to close the Sun Roof! When driving down the road it doesn’t bother me as long as it’s a smooth road. However, if I’m on a dirt road with pot holes or go over a bump the whole truck and truck camper reacts violently. Even going to the end of my block has a difference in heights that my truck with camper will bounce badly so I drive real slow crossing over from one block to the next.
Years ago in the 70’s, I had a Chevrolet and Open Road camper with cabover struts. I can’t remember if they helped or not. I have tried to find some Cabover struts for my Ford F-450 and Chalet TS-116 but haven’t found any. Where did you get yours at? How are they working for you? Thanks.
