Rover_Bill
Aug 19, 2019Explorer II
I've had my ReCurve R6 with 1200# bars since 2016 and have over 20,000 miles towing. I LOVE it and highly recommend it! You can have perfect weight distribution if you take the time to set it up correctly. The sway control really does work and you don't have to worry about it when making tight turns and backing up at gas stations or into parking spots. The design of the bars gives you extra clearance where other WDH would drag.
My major dislike is that you need a separate hex key to engage/disengage the TWO sway control dials. Order a few extra keys (I lost 2 already). Engaging the sway control is very easy when the TV and TT are perfectly aligned or more than 10 degrees out of alignment (i.e. turning). It's VERY VERY difficult when they are just slightly out of alignment.
The R6 hitch is heavier then most other WDH. A HitchGrip helps installing/removing the hitch from/to the receiver.
