richardcoxid
Aug 20, 2019Explorer II
Thanks to ALL who have responded to my original post!
I guess that I should have included more information in my question.
Sometime back in the late 80’s or early 90’s We purchased a 26’(?) Road Ranger TT from a local dealer (no longer in business) included in that package was a WD hitch with a Sway Control feature (brand unknown)
What I remember is that it was a round spring bar that attached from the bottom of the hitch. At the flat end of the spring bar was a flat topped pyramid of a “sticky soft white metal” that mated with an inverted flat topped pyramid which “locked” the TT/TV in the anti sway position. When you turned the TV/RV direction, the lateral movement of the spring bars caused the slope of the pyramids to “unlock” allowing non-resistance to turning the unit.
Guess that I am somewhat biased in my thoughts, even though it was primitive compared to what is available today, it worked, “locking” for towing and “un-locking” when turning. The CAMCO R6 would be the modern version of what I remember.
The Reese Straight Line Dual Cam hitch is another one that locks/un-locks. However, it is some what more expensive (not really an issue), more complex, slightly heavier, difficult on the initial set up and adjustment, though after initial set up, hooking up really isn’t that difficult.
