Rover_Bill
Aug 20, 2019Explorer II
carringb wrote:
...The R6 hitch is still predominantly friction based, so you'd have to "turn it off" in wintry conditions....
EAZ-LIFT has two versions of their ReCurve hitches - R3 and R6. The R3 version is friction based. The tighter you screw down the clamp the more friction is exerted to keep the trailer from going out of alignment (and more friction to keep the trailer from RETURNING into alignment). You must manually totally loosen the screw clamp to turn off sway control.
The R6 control uses two SPRING LOADED bearing for control - one under each bar. The bearings help resist the trailer from going out of alignment but once it is out of alignment (less than 10 degrees) the bearing actually help PUSH the trailer back into alignment. If the trailer is more than 10 degrees out of alignment (as when turning) the bearings are disengaged and there is no extra force on the hitch. You can manually engage one bearing for partial sway control, two bearings for full control, or leave both bearings disengaged for no control.
