lgroat
Jun 20, 2016Explorer
allen8106 wrote:belairbrian wrote:
Are you running the fan on low at night? if so the unit may be icing.
I'm inclined to think this might be the issue. Make sure you run the fan on high speed. Low speed will not put enough air flow across the evap coil and it WILL freeze up. Especially in cooler temps (Like at night).
We did set it on low. When the compressor cut off, the fan cot off also. If the compressor freezes up, does the fan cut off? Seems like the fan would keep running
44,056 PostsLatest Activity: May 04, 2014
