jasonpeloquin84 wrote:
I'm not understanding why it now needs a battery to run while hooked up to shore power. It ran for 10 months with no problem, with no battery. Could it be the new type of convertor that i installed? Where would the 12VDC panel be located? The only 2 fuses that i saw were on the convertor and both good.
It wouldn't need a battery. You need to trace the thermostat wire BACK to the converter. it needs 12v power to run it. Simple as that. obviously your mouse chewed it as well. Once you find the wire check for continuity with an Ohm meter.Simple as that
