wnjj wrote:
mkirsch wrote:
wnjj wrote:
That's weird. I wonder if there's a compatibility issue with your plugs and sockets? The reverse lights are the center pin and it's pretty hard to have that swapped.
Actually, it isn't.
The center pin on my Palomino is the 12V power for the fridge, which isn't even connected.
So they didn't wire the camper plug the same as the truck (i.e. the RV 7-pin standard)? It doesn't make sense to me to use the same type of connector then not wire them the same.
7-pin commercial connection doesn't use the same pin/wire pattern as 7-blade RV connection.
