msiminoff's avatar
msiminoff
Explorer II
Oct 24, 2013
Camper Dolly
When not in use, my TC is stored inside my warehouse. It's safe, dry, & temperature controlled which is great, but I have finally gotten fed up with the amount of jockey'ing it takes to get the whole rig into the back corner of the building... not to mention getting the truck back out after unloading :M
So, this morning I built a simple steel dolly on wheels. Now I can back into the roll-up door, raise the camper, pull the truck out, slide the dolly under, and lower the camper onto it. Rolling the dolly (w/3500lb camper on board) across the concrete floor is a simple one-man job, but steering is easier with 2 people since all of the wheels are swivel casters.
Here's a few pic's;
The dolly is 33" tall (truck bed is ~34") which minimizes the amount of time I spend running the jacks up and down.
There's a 3/4" plywood deck on top of the dolly and I'll be using a second piece of ply on the lower shelf l for storing my cargo rack, motorcycle rack, tailgate, etc.
The best part is that I can now quickly & easily get the camper tucked all the way into the corner.
BTW, my shell is stored on a rolling dolly too :C
Cheers
-Mark
  • I bet that camper sits very firmly on your dolly without any shimmy or sway.
    The dolly is made from 2" x .120 wall square tube and 1" X .090 tube for the lower shelf & diagonal bracing. It could easily support twice the weight of my TC... there is zero "shimmy or sway" ('cept for the fact that the casters can roll) ;)
    What would you do different if you were building another? Would you go with non-swivel casters on one end?
    I had plenty of time to think about my needs and the design of the dolly before I started cutting up the steel... Given my storage situation (busy/crowded warehouse, flat & level concrete floor, high ceiling), I can't think of anything at all that I'd change.
    Since in need to maneuver the camper into the back corner of the warehouse, I wouldn't choose fixed casters, but I would certainly consider using casters with a swivel lock.
    -Mark
  • msiminoff wrote:
    I understand your reasoning for having it 33" tall. I would probably make mine a little shorter.
    Questions: what would you do different if you were building another?
  • That lower shelf adds a lot of support to your dolly legs. That's always a worry when using an elevated platform. I bet that camper sits very firmly on your dolly without any shimmy or sway.
  • That's a real nice job. And good that you have so much, high room.
