Locatuse
May 07, 2014Explorer
beemerphile1 wrote:
Your description is confusing. Is the GFCI tripping or is it a breaker?
If it is the GFCI tripping then you have a ground fault not a shorted circuit.
The gfci that has two normal outlets is tripping. It is beneath my breaker panel which nothing is tripping on that. And between my two rv hookups that neither of my rv lines are long enough to reach.
Also the breakers inside my camper are not tripping. It's the gfci outlet on my power pole.
