beemerphile1
May 07, 2014Explorer
Locatuse wrote:beemerphile1 wrote:
Your description is confusing. Is the GFCI tripping or is it a breaker?
If it is the GFCI tripping then you have a ground fault not a shorted circuit.
The gfci that has two normal outlets is tripping. It is beneath my breaker panel which nothing is tripping on that....
You have a ground fault.
A ground fault occurs when there is an imbalance between the hot and neutral wires. That imbalance is often caused by water intrusion in an exterior receptacle.
Because the problem is intermittent, that is another sign of a possible water issue. Any outside receptacles on the RV?
