Rhodesia wrote:
well I'm not level inside I have a bubble it looks like the camper can be lifted in the back on the camper by putting a 1/2 inch board underneath it just to level out the nose on the overhead part to make it even and not look like the nose part is pointing to the sky, you also can not even see the marker lights on top of the nose cap when looking from the front so in another words your marker lights are facing the sky. Again the ford dealership says my truck bed rail sides are not tapered to where the tail gate is higher than front of the truck bed even the bubble level says its even, But the Lance dealer still insist that this is correct and it will look like your camper is leaning at the back end. My center of gravity is correct and I have a 1/2 stall pad for a camper mat for the truck bed
look at the overhang over the cab, does that distance between them seem normal and even. if so then it is you truck that is saging in the back making it unlevel.
by tapered they do not mean they taper up. they taper inwards so the rails at the back of the truck are closer togeather than at the front of the box. this creats a optical ilusion with an overhang of a camper.
