scubabri wrote:
Grit dog wrote:
Mkirsch usually isn’t so much use or obtuse. He’s a good guy, but I got the same vibe as you.
That said, if the previous 5 pages doesn’t give you some more ideas or context, then likely the future responses won’t either.
It just wasn't clear to me what the ultimate solution was. It appears that crowning in the bed can cause this, but it's just not clear.
I'm going to get a borescope and see if there is indeed a gap at the front of the bed when the camper is in that would indicate that it's riding on a crown and tilting towards the rear.
I'll report back.
There really wasn't a solution just more of the same back and forth. I posted some pics and after that I tried to get it perfectly level but with no luck. My Chevy bed is slanted to the rear and closer on the sides in the rear than in the front. That was my answer. Good luck with yours!
