tbltony's avatar
tbltony
camper pass through donut
does any one have experience with a camper to truck donut other than the lance foam rubber one. my foam rubber one coming apart and I would to replace it. we have a cat and she needs to have free passage. any help would be appreciated. thanks
  • Northstar campers also has a passthrough donut similar to the Lance item. See your local Northstar dealer or talk to Rex at Northstar.com. The one I bought works flawlessly.
  • Naio wrote:
    OK, I just had to know what the heck you were talking about, so I googled it. Not much online except for here, at rv.net :).
    But I think this thread on options might be just what you need:
    http://www.rv.net/forum/index.cfm/fuseadoughnutsction/thread/tid/27559471/gotomsg/27562344.cfm
    And now I know what a donut is!
    Learn something everyday.
    Now on to sewer doughnuts......:)
  • We use a 5 gallon pail, cut 4" off from the bottom go to Walmart buy a tube type float that you inflate. Mount the deflated tube in the middle of the bottomless pail duct tape it so it doesn't slide back and forth. The tube should fit snug without the tape. Position the pail in the pass thru and make sure the tube fits between the TC and truck than inflate. We use a portable compressor and slowly watch to make sure the tube inflates evenly. We have two small dogs that run back and forth from truck to TC trying to be the first thru the pail. They think it's a game. Tube has lasted over 13,000 miles and still holds air. Caution remove before taking the TC off the truck and don't over inflate the tube just snug enough not to let wind and bugs in. Gerry
  • Naio's avatar
    Naio
    Explorer II
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27559471/gotomsg/27562344.cfm
    Would pool noodles strung together work?
