69_Avion
Jun 30, 2013Explorer
The length of frame you have, has some "give" to it. With the proper amount of stabilzer jacks in the right places it should stop most of the movement. I would set it up at home and put the factory stabilizers down, then put hydraulic jacks with cribbing in various locations to see what helps the most. Once you find the areas that need support, install more stabilzer jacks.
44,056 PostsLatest Activity: May 04, 2014
