Bedlam
Feb 19, 2014Moderator
rickeoni wrote:
Any idea on how to make it bigger and still post on the board?
When you converted these pages to JPG, you saved them with a resolution of 306x319 which makes the text hard to read. Doubling the resolution in the conversion should make them legible.
On my toy hauler, the AC source was selected based on where you plugged in the whip. This whip was inside a compartment that had two female plugs. One plug went to the generator and the other to the inverter. The whip was pulled out of an access hatch if you you used campground or external power. There was no need for an isolation circuit since you could only be plugged into a single AC source at any one time. It also made it easy to power the house or welder off the 5.5 Kw generator since there was an isolated full rated output.
