cewillis wrote:
I suppose taking the camper off the truck, and putting it on a rolling cart/platform is not an option?
Halibut214 wrote:
I took my camper off outside and rolled it in my shop on car wheel dollies.
no too steep and not level. At least for my comfort level with a 5000lb camper!! and the first 6? feet outside the doors is gravel currently.
sch911 wrote:
I think you could go down. Change the slope of the grade leading in and pour a new floor on that side. Then modify the existing door to fill the gap.
K Charles wrote:
you only need to drop the floor on that side for a few feet then add another panel to the door. I have seen a lot of old repair shops with a 5 or 6 ft ramp on the inside of the door.
The existing door isnt wide enough anyway. The Lance with no side awning only had 3" of clearance per side. The new camper has a side awning so I'd have no margnin of error.
Super_Dave wrote:
Replace the conventional garage door with either a roll up type door mount on the face of the opening or maybe a rolling track door that would slide over in front of the other garage door. Outside the box for sure.
I looked at those. Besides being very industrial looking they are VERY expensive. It was over $7k just for the door.
