Nvr2loud wrote:
W.E.BGood wrote:
Nvr2loud wrote:
My tires have a max rating of 35 psi
Does that seem low?
They are Goodyear marathon trailer tires and I was surprised to find such a low pressure rating
What kind of TT do you have and what is the trailer's recommended inflation (per tag or manual)?
The rating plate in the side of the trailer is sun faded but the trailer is an r-vision trail cruiser 30QBSS
According to a used-RV web site your trailer has a gross weight rating of about 6K lbs. It also lists the tires as 205/75R14. Goodyear Marathons in this size are load range C and the max inflation pressure is 50psi. Are you sure about the 35psi max? The tire rack doesn't even list a Goodyear Marathon in any size with max inflation pressure less than 50psi.
Steve
