JIMNLIN wrote:
Older 14" Marathons (others brands also) came in a load range B at 35 psi which was basically a P tire.
With a 6k gross weight divided by 4 tires = 1500 lbs per tire requirement. Subtract 500-600 lbs hitch weight leaves 1375 lbs on the axles. A ST205/75-14 C at 50 psi and 1760 lbs of capacity would be a good choice for a tire when replacement time comes.
Thanks!
I think that the tire replacement will be very soon. I'll store the trailer over the winter with the existing tires and replace at the start of next season.
