eou_edu
May 23, 2014Explorer
Campers under $10K
Hello forum. My name is Corey and this is my first post. I've been researching the past few months on here and trying to figure out what camper I should buy. Unfortunitly reading about others experience can only get you so far and I'd like to try and make the right choice before I buy something. Now I think I'm more confused when I started. So I'm turning to the experts for help.
1) Rule number 1. No leaks, no leaks, no leaks!!! I live in Oregon and it rains a lot here. I understand taking care of it is important, but the less I have to think, worry about, and predict leaks before they happen the better.
2) I have a 2006 dodge 2500 diesel but prefer something small and light, 8ft with no overhang is ideal but they are few and far between anymore.
3) I would take it mostly hunting. I don't plan to four wheel with a camper on but sometimes logging road and forest service roads can get a little rough. I'm trying to avoid a pop up because to me it just seems like a $12000 tent. However I'm afraid I might be asking for trouble if I use a non pop up camper.
4) Alaskian? I have no opinion except even the new ones look.....Rustic?
5) Capri campers: I'm tempted by these but they seem to have a lot of leak reports.
6) Northern lite and bigfoots. Seem to be the holy grail of campers. But i've also heard complaints about not handling off road very well. Is this just opinion or is in warranted? I thought about buying an older used one and getting the width cut down to fit my newer box, but two quotes of $2400 detoured me from this. They seem to be a good deal for someone with an older truck though since the used market on them is limited to wider box older trucks.
7) Panther campers. I just discovered these and very close to my home in Vancouver Washington. Aluminum frame, fiberglass campers. They build them custom to my specs. They start new at $9,000 then go up as you add options. They have fiberglass panels, on aluminum frame, and have a "triple sealed roof" (seamless sounds like a better term but triple seal sounds pretty good as well). I' toured their factory and they look very impressive. Best of all they will build how you want them and in this case they build with no holes in the roof! Really who needs vents when you can have no leaks? I am still worried about off road and seems coming apart and some talks of "delamination." As well as killing my budget!
8) I horse traded a friend a few months ago for a stable lift system. Still trying to figure out if I want it on whatever camper I get. Extra weight and loss of ground clearance is not so good for hunting. But ability to take it off and on quick on less than perfect ground and have a free truck to hunt in is a big plus.
9) I'm open to any other suggestions?
I know 9 questions is asking a lot, so I thank any help someone wants to give to a newbie.
