eou_edu's avatar
eou_edu
Campers under $10K
Hello forum. My name is Corey and this is my first post. I've been researching the past few months on here and trying to figure out what camper I should buy. Unfortunitly reading about others experience can only get you so far and I'd like to try and make the right choice before I buy something. Now I think I'm more confused when I started. So I'm turning to the experts for help.
1) Rule number 1. No leaks, no leaks, no leaks!!! I live in Oregon and it rains a lot here. I understand taking care of it is important, but the less I have to think, worry about, and predict leaks before they happen the better.
2) I have a 2006 dodge 2500 diesel but prefer something small and light, 8ft with no overhang is ideal but they are few and far between anymore.
3) I would take it mostly hunting. I don't plan to four wheel with a camper on but sometimes logging road and forest service roads can get a little rough. I'm trying to avoid a pop up because to me it just seems like a $12000 tent. However I'm afraid I might be asking for trouble if I use a non pop up camper.
4) Alaskian? I have no opinion except even the new ones look.....Rustic?
5) Capri campers: I'm tempted by these but they seem to have a lot of leak reports.
6) Northern lite and bigfoots. Seem to be the holy grail of campers. But i've also heard complaints about not handling off road very well. Is this just opinion or is in warranted? I thought about buying an older used one and getting the width cut down to fit my newer box, but two quotes of $2400 detoured me from this. They seem to be a good deal for someone with an older truck though since the used market on them is limited to wider box older trucks.
7) Panther campers. I just discovered these and very close to my home in Vancouver Washington. Aluminum frame, fiberglass campers. They build them custom to my specs. They start new at $9,000 then go up as you add options. They have fiberglass panels, on aluminum frame, and have a "triple sealed roof" (seamless sounds like a better term but triple seal sounds pretty good as well). I' toured their factory and they look very impressive. Best of all they will build how you want them and in this case they build with no holes in the roof! Really who needs vents when you can have no leaks? I am still worried about off road and seems coming apart and some talks of "delamination." As well as killing my budget!
8) I horse traded a friend a few months ago for a stable lift system. Still trying to figure out if I want it on whatever camper I get. Extra weight and loss of ground clearance is not so good for hunting. But ability to take it off and on quick on less than perfect ground and have a free truck to hunt in is a big plus.
9) I'm open to any other suggestions?
I know 9 questions is asking a lot, so I thank any help someone wants to give to a newbie.
  • I too own a Capri camper & would be very interested where you found leak reports. Are you sure the reports are for Capri TC, not Coachman Capri trailer?
  • I question this one:
    " 5) Capri campers: I'm tempted by these but they seem to have a lot of leak reports"
    I owned two of them and didn't have even the tiniest of leaks.
  • For a camper you are just going to have to look at what is available used in your area. Just a few general comments, if you go look at a camper and the weeds/grass are 3 ' tall under the camper it may not have been taken care of. If it's sitting under a carport or in a garage/barn there's a chance it has been taken care of. I don't care what brand you buy they ALL have the potential to leak, they just move around to much to not possibly leak. A good inspection is key........inside and out ! Also try to judge if the seller is honest or not this is a tough one but your gut will probably send out warning signals if it just doesn't feel right. Being a Stable Lift owner I am biased but for my Avion C11 restoration it is the best solution and I will never get rid of it. Good luck in your search.
