sabconsulting's avatar
Sep 19, 2016
Camping well below freezing - Sweden over winter
Friends of ours have taken a job working 150 miles north of the Arctic circle in Sweden this winter. The temperature gets down to -35 Celcius.
They will be living in their small truck camper. It is a Swedish-made camper so should be capable of reasonably cold conditions, but may not be designed for -35C.
They will have electric hookup.
It is on a diesel truck. Has fresh water and propane tanks as you would expect, plus a grey water tank and a cassette toilet. Hardside, not pop-up. No slide. No basement.
I've seen various things written here about winterising campers, but I assume they are for people storing their campers unused over winter as opposed to living in them.
Does anyone have any advice for coping with these temperatures - what can they put in place in the camper before they go? What do they need to be careful of?
Thanks in advance,
Steve.
  • Oh and yes you'll need to heat the propane tanks too, or I take back the statement about not dying!
  • I spent 2 winters working north of the Arctic Circle, north slope AK.
    I'm the guy that says you can tow 10klbs behind a half ton and it's ok to overload your tires, but I can't condone this.
    If they're smart people they won't die......but why??
    In fact it's one of, if not the worst idea I've ever heard. And just cause the camper is made in Sweden doesn't mean it's made for that. People die in car accidents in Volvos too!
    Some of the questions on this forum are what make me keep coming back, like watching a train wreck....can't look away!
    Is it April fools day already?
  • I added a water circulating system to prevent pipes freezing. I believe he may need something of this sort. Also tank heaters and double them up. www.ultraheat.com At -35 I would have a second method to provide at least half the BTU of the main furnace. Could go through a lot of propane so best to have an external connection to a large tank. Propane tank may also need electric heat as it will fail to vaporize fast enough as you get into this temperature zone.
  • That's just crazy. As a matter of fact, it's downright dangerous, IMHO. My advice is not to do it. Surely there are other accomodations available.
