ktmrfs
Dec 03, 2018Explorer III
I've got 10 years experience camping with a CPAP. A lot of "fear" that IMHO is unjustified. My observations
1) unless the CPAP is REALLY ancient it actually runs off either 12VDC or 24VDC ALL the time. the wall wart takes 120 and converts it to DC
2) CPAP is more efficient running of 12VDC (even 24V units have a 12-24VDC converter)
3) there are multiple sources including the OEM to get a 12V adapter for the unit... Get one
4) for longest battery life turn off the humidifier, turn it to airplane mode if it has wifi. If you want you can put warm water in the humdifier tank at night and you will get some humidification from the airflow. Personally I just don't use the humidifier function when on battery power.
If you do this, you will likely draw 1-2A DC. or 8-16AH each night. Even a 75AH battery this will get several nights out of even a single 12V battery. More than likely the other things on 12V will use this much or more current each day. Fridge on propane, a few lights will equal or exceed the daily AH of the CPAP.
so, with one 12V battery, even without a CPAP you can run the battery down to 50%SOC in a few days, especially if you don't have LED lights and aren't careful. I suspect many times when the battery is dead in the morning the CPAP gets the blame, when it's really daily draw and CPAP together and the battery would be dead by the next night anyway. Or that the CPAP is on humidify and using a inverter to get to 120V then to the CPAP wall wart, not very efficient.
Using humidifier current draw can rise to 6-8A, enough to run down a single 12V in one night. current draw is highly dependent on temperature, so if it's a cold night....... current draw will be highest.
good camping. And to the OP, if your going to dry camp for more than a few days I assume you have a good generator and I'd suggest having two 12V batteries or a pair of 6V and likely need to swap out the common WFCO charger with a PD or similar drop in unit if you want to charge the battery quickly with a generator. The WFCO is known to often only give about 15A of charging current rather than the claimed 45A or so. Makes for a very long charging time.
44,068 PostsLatest Activity: Jun 14, 2026
