Momatude
Mar 05, 2016Explorer
this is the info we have for our Toyota with a tow package and sway bar add ons:
Weights and Capacities
MAXIMUM TOWING CAPACITY**5000 lbs. MAXIMUM PAYLOAD**1679 lbs.
GROSS WEIGHT6000 lbs. DRAG COEFFICIENT.34 Cd
CURB WEIGHT4321 lbs. ANGLE OF APPROACH29 degrees
ANGLE OF DEPARTURE24 degrees CARGO CAPACITY, ALL SEATS IN PLACE10.3 cu.ft.
MAXIMUM CARGO CAPACITY95.4 cu.ft.
** When adequately equipped, which may require engine and/or other drivetrain upgrades.
DRIVE TYPEAll wheel drive TRANSMISSION5-speed shiftable automatic
Engine & Performance
BASE ENGINE SIZE3.5 L CAM TYPEDouble overhead cam (DOHC)
CYLINDERSV6 VALVES24
VALVE TIMINGVariable TORQUE248 ft-lbs. @ 4700 rpm
HORSEPOWER270 hp @ 6200 rpm TURNING CIRCLE38.7 ft.
Suspension
MacPherson strut front suspension
MacPherson strut rear suspension
Four-wheel independent suspension
Front and rear stabilizer bar
Suspension
44,066 PostsLatest Activity: May 13, 2026
