Grit_dog
May 18, 2022Trailblazer
Johnsonty131 wrote:
So once I get a weight distribution hitch it shouldn’t be any problem correct?
I wouldn’t expect any problem before you get one either.
Seriously look past all the bs responses here and think about the 1000s of big trailers. Bigger than that that get hauled around all day every day with 1/2 ton trucks and no wdh.
Literally wdhs are about 99% a RVer thing. Yes some travel trailers pull poorly from a sway standpoint due to axle placement, rear overhang, designed heavy in the rear or not enough tongue weight, although it’s not common.
For a hitch, if you are just getting something to get you by, just get a minimum class 3 stinger and the right size ball. Either figure out the hitch height and the amount of drop (rise actually) that you need, or get something with about a 3” rise. Should be close.
Congrats on the new camper! And don’t sweat it. Enjoy the drive!
And don’t listen to the paranoid folks.
