MO_Trout_Bum
Jun 05, 2013Explorer
My two cents.... based on the numbers provide, OP will likely be somewhat over, both payload and hitch weight ratings. Both somewhat concerning, however from my experience in towing longer TT's with short wheelbase SUV's (Tahoe & Yukon), sway and general handling will be the most significant concern. Even with something solid like the Reese dual cam setup, you WILL have sway in windy conditions and WILL be affected by semi's passing. No way around that, and the short, halfton SUV's are less capable in handling the effects. If I was you, I would look at shorter, lighter TT's.
44,066 PostsLatest Activity: May 13, 2026
