ryanw821
Jun 23, 2015Explorer
LarryJM wrote:
I haven't read all the posts, but I would not recommend using Eternabond even the double sided stuff to secure anything. It is not a good adhesive since the microsealant is soft especially when warm and stretches. If you pull on the microsealant constantly it will release a lot of times from the surface. If you want a good adhesive look at either the 3M Marine UV 4000 and if securing items like wires the 5200 might be O.K. however the 5200 is not UV protected so I'm not sure how long it would last.
Larry
I ended up using 3M 5200, but it's on the back side, so should not get any sunlight/UV.
