- dodge_guyExplorer II
Steve S wrote:
Isn't the reason the dumps are on the right side of the trailer so that we can open them while driving down the road?
Yep, that is why they have the culverts in the middle of the highway! - popeyemthExplorerSTOP IT
you guys are making my side hurt LOL - Steve_S1ExplorerIsn't the reason the dumps are on the right side of the trailer so that we can open them while driving down the road?
- westendExplorer
calamus wrote:
So, if I drink some potable water and it goes through my personal processing plant, that would be considered "potable water discharge"? :Bpopeyemth wrote:
Denis,I think "potable" means "drinkable,unpolluted"
So you would drink the water from washing your car or water run off from the lawn sprinklers? And Discharge from a potable water source would be your grey Tank as the water is potable that is going into the tank. Dennis you are correct! - FLman2ExplorerWith so many making comments, could it have some to due with the cold weather much of the country is experiencing? Just wondering...........
- Monaco_MontclaiExplorerI waz under the idea, that all waste water had to be treated ALL, wow now it's all happy-camping
- popeyemthExplorer
I would suggest the use of a dictionary. Dennis is quoting a source that refers to "potable water DISCHARGE " reguardless of the source grey water is no longer potable or it would be fresh water not grey. - 2112Explorer III can only speak from my neck of the woods; dumping grey water into the storm drain is illegal, dumping it onto your private 'Residential' property, i.e. front lawn, is legal. Our storm drain discharges straight into the bay.
Go figure. - LockyExplorer
wrvond wrote:
The answer to your question is:
"I don't know."
You'll need to check with your city code enforcement officer. If you don't have one, check with the county code enforcement. They'll be glad to answer your question without insulting you.
The best answer so far. - YardvarkersExplorerI have a 1,000 gallon septic tank and 300 ft. of leaching lines. Where does it go?? answer.... IN THE GROUND.
:B
44,056 PostsLatest Activity: Nov 19, 2013
