Gdetrailer wrote:
HuckleberryHunter wrote:
CAN you? Yes. SHOULD you? IMO, no.
WDH is there for a reason.
OP has a 3/4 ton truck with a heavy Diesel engine and has 4K of cargo weight available..
That truck will never need any weight restoration on the front with even 1K lbs of tongue weight.. 1K of TW most likely will barely lift the front and I doubt because of the Diesel engine will every be missed.
WD hitches were designed to allow vehicles to tow much larger loads than they were originally designed for by pushing some of the tongue weight which would have overloaded the rear axles forward to the front axles..
OP has the option to not use WD if they choose to do so. The only caveat is to make sure the trailer TW is above 12%, ideally 15% for best towing stability..
For the record, I have never used WD on any of my 3/4 ton trucks and have towed 20ft and 26ft trailers with 7K GVWR and have a 10K GVWR 18 ft flatbed trailer that I have loaded well over 10K and never had the headlights point to the sky as folks love to banter about..
I've seen plenty of 2500 diesels with their headlights towards the sky. I'm not sure how much tongue weight those landscaping trailers have but they're the most common offender. Beyond that there vast majority of wdh also offer another significant advantage which is anti-sway and sway is one of those things that by there time it rears its ugly head it's generally too late.
