theoldwizard1 wrote:
BradGalloway wrote:
Thanks for the reply. I have a 5.3 EcoTec3 V8 (L83) 2WD Crew Cab with 3.42 rear end.
I plan on mostly flat. Wind is regular, but not terrible here. Just didn't want an unsafe load or really kill the truck.
higher (3.73) rear axle ration
a 3.42 is a higher gear than a 3.73. Even though the numbers are higher. The gear itself is quite a bit lower. Providing more torque to the rear wheels. Higher numbered gear ratios are lower gears than lower numbered gear ratios.
Not tryin to be smart. Just thought you would like to know. If you didn't.
If you had ever seen them run together you would better understand. With a higher numbered gear. The pinion just spins like a top, while the ring only goes around a couple times. Pretty cool to watch thru the tester window.
