Engineer9860
Jun 16, 2013Explorer
You can't change a filter too often.
Keep this in mind: As long as there is no movement of the filter minder indicator you can assume that there is no, or little (insignificant) filter restriction. If you have any movement whatsoever, even if the indicator is still in the green, you have a restriction, and you are losing engine efficiency.
