tractorboy30's avatar
tractorboy30
can I use a site with 50amp with my 30amp plug??
Hi like it says can i use a 50amp plug in at the campground with a 30amp plug and adaptor?? will it cause any problems with my trl?? only asking as the site we would like to book is only 50amp thanks
Frank
  • Right On Ill Stop by my dealer and pick up a adapter plug for it then and take the site we want rather then take one we don't thanks again everyone :)
    Frank
  • You just may have to cut back you're usage... Two A/C's microwave, and coffee pot might not all get along at the same time with 30A. Just be careful.
  • tractorboy30 wrote:
    So the 20amp more wont hurt my trl?
    Nope. Electricity isn't like that. 50Amp is what is available to be used per hot leg (a normal 50 amp service has 2 hot legs for a total of 100 amps available). Your normal 30 amp plug has one hot leg and the service provides 30 amps available. Your trailer will be perfectly fine
    In fact I plug my 30 amp trailer into 50 amp service anytime it is available. Generally the 50 amp service is newer and less used/worn than the typical 30 amp service plug
  • aslakson wrote:
    No sweat. Use the 50 to 30 adapter, and all will be good.
    al
